i think i'm gonna do two taramp MD8kws. i'm going to try to address the broken roof again. they just get bottom heavy the bigger i go honestly. right now they drop low enough and i'm tuned around 42.you wont get 7.5 per driver, more like 5kw
Thanks for the input though.oh lol
I wonder when they got away from tight gap? The older ones I've rebuilt were very tight gap, almost as snug as my neos, not quite as tight as '05 Sig.9515i. The series before they went to the bigger coils. After I get 15kw they won't be able to handle the power in 7.5 per driver..
So you're saying if your cone is moving 20mm with 5000W in a 5 cube box it's going to be louder than the cone moving 20mm off of 2000W in an 8 cube box? What does the modeling predict? There should be a point where adding box volume gains significantly then you hit a plateau where you don't get much else for going larger.and having a box too big hurts output because it starts to unload like it's freeair.
Displacement is the same with all over th things being equal they will be the same.I wonder when they got away from tight gap? The older ones I've rebuilt were very tight gap, almost as snug as my neos, not quite as tight as '05 Sig.
beaumont txI still call complete bullshit. This fool isn't breaking cones.
That's not cone breakage fool. That's the surround separating from the cone.beaumont txone is abit softer
i'm about to put more than likely 2 taramp MD8ks on them. i might recone them and grab a bigger korean at .33 kevlar of course
no **** the cone is soft right here. there is no way to capture it *** clown.That's not cone breakage fool. That's the surround separating from the cone.
Probably from it beating against the loose surround. That is totally unacceptable and I'd be contacting DD or whoever sold you those recones. That glue should never fail.no **** the cone is soft right here. there is no way to capture it *** clown.
i tried. they said that i should upgrade and give them 750 for new recones. that's why i'm border line about to dump them and grab some omegas.Probably from it beating against the loose surround. That is totally unacceptable and I'd be contacting DD or whoever sold you those recones. That glue should never fail.
its possible. my friend noticed it honestly. i feel a groove so to speak. the camera won't pick it up. i don't know if its a void between the fibers or what but its odd.. i don't feel like pulling them out to show some morons some pics. im done arguing with people here because none of them putup.Probably from it beating against the loose surround. That is totally unacceptable and I'd be contacting DD or whoever sold you those recones. That glue should never fail.
Implying if they can't glue the surround to pulp they'll get it right glued to composite. Absolutely inexcusable place for a cone to fail.i tried. they said that i should upgrade and give them 750 for new recones. that's why i'm border line about to dump them and grab some omegas.
