Box size too big?
I would get a better box when you decide to get a better sub. Just my two cents, the new RF line up is quiet disapointing.
But yes a good box tuned for the strenghts of the sub will be much better.
I have a Rockford Fosgate P3D2-12 sub and im looking for a box. It says i can have 1.25 cubic feet max for a box. if i buy a box that is 1.3 cubic feet should i be ok? and what does more or less space do to the sound of the sub?
Thanks
All things being equal a larger box will play lower and be more efficient, and generally be less peaky... Differences of say 10% in volume or tuning frequency are probably close to inaudible for your purposes.
In addition to a well made box, attention to position of the box in the car (dependent on the car itself), and orientation of sub/port will make a dramatic difference as well. That's often why the cookie cutter pre-fab boxes often don't work and why many of us re-build so many times to test different things.
Did you just say a larger box is less peaky? While this is relative to the woofer its self, over all this is not true..
Your system is pretty much 30% subwoofer and 70% box/enclosure...A poorly designed/built box can really bring down the overall performance.
This. ^^
Put that in a 2 Cubic foot box, preferably ported. It will only get louder and lower.
If that is a 2010/2011 P3, it will pound the hell out of a big box.
Could you guys suggest a box for me? 12" probably sealed
If you've got at least high school wood shop skills and a couple of tools, just build it yourself. It will cost you around $30 in materials and an hour or 2 of your time.
Especially if you want a sealed box, which are the easiest to build.
Ya you should definitely get a custom box built when you get the subs you want to stick with! I went through about 4 prefabs before finally deciding to get one custom built, and WOW what a difference! Definitely not internet bs! With all my prefabs when I would try to hit a low note it would just sound like the subs were gurgling for air! Now with the custom it hits like a sledgehammer!
Ive actaully heard the new p3's just recently in my guys 350Z build. It was 2 p3 12s and i thought it sounded really good. But ull deff want someone to build you a real box lol
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
asousa757
asousa757
Virginia Beach, VA
Moble Enclosurs
    May 31, 2024
    May 24, 2024
