youdoofus
Skibidi
- Thread Starter
- #31
i might be better off just going full trunk as the trunk is basically useless as it sits now anyways and i never use the car for long trips because of the lack of space as it currently is and just forgo the spare. Leave it at home and make sure i have someone to call if the need arises. Im not sure how much of a pita it would be to get at the spare right now anywaysNot only that but your head unit is putting out a certain voltage, and setting your gain is matching that voltage. So depending on the voltage your head unit is producing, 1/4 gain might be full power, or full gain.
Now as for fitting two 12's in a trunk Ported, you aren't going to do it without it taking up most of your trunk. You need a certain amount of Port area or you risk annoying port noise and compression issues. So just doing a small port isn't really an option unless you go with a bigger box. Small port and small box don't really go together, which is why designing a good box is often challenging when limited in space.
Most 12's Ported need about 4 cubes. And judging by the size of the 4ft box in my truck, good luck lol. Go check out the box I posted in the build log section for two tens in my brothers focus, that's only 2 cubes. Two tens are very practical for people worried about getting to their spares while still having a Ported box that bangs.
i did rather like it as it was before my slew of amp problems. ill probably just focus on the charging system for now and go from there
The 1/3 gain wasn't just some arbitrary level I set it Ro btw, I went to an empty parking lot, turned the deck up to the max I'd ever have it at and turned the gain up until the just a bit before the clipping light would flash on the heaviest tones. It has a bass knob with a clipping light too and it rarely, and I mean rarely even barely flickered
