Box Design
uzy
O
hey
im trying to design a box for the RE SX 15" i made a box but im not sure if it looks correct
http://www.subwoofertools.com/forum/ported-box.asp?Ew=29&Eh=16&Dia=9&Xmax=22&Vd=0.22&NumW=1&Vb=3.5&Fb=32&Qts=&Vas=&Fs=&CE=0
also were do i mount the sub woofer, and also should i smooth all the edges of the wood involved in the port area. and should i also put silicon sealent in each of the joins in the wood so its all smoooth:fro:
Do you really need 65^2 or port for that sub? Not familiar with RE specs, so that's why I ask.
If that's too much you can change the xmax until you get the desired port size.
well im not sure either thats why i was asking if it was aright, obviously im a newbie to this. i used the x max form the sub and its 22mm. i put in all the stuff i needed such as the box size and tuning frequency, xmax, and driver displacment. i got all the info off the re internet site.
120
419
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
570
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
uzy
uzy
O
uzy
audiobaun
    Apr 27, 2024
audiobaun
    Apr 27, 2024
