This chart is what Andrew "Black Nasty" posted on the soundqubed only group on facebook.
Here is my input on what I have found to be optimum in sound and overall performance (SPL) for both the HDC3 and HDC4. Now there are several versions of both of these subs and I have tested countless hours with both. This is my recommendation, it isn't intended to be the end all BEST but will get you really **** close
All recommendations are with alum coil D1 subs. Single sub setup, simply multiply for multi sub setups, works great in my testing.
HDC3 old version (Old Style basket) Stiff suspension
1k input power
HDC310 - 2.0 cube net with 18 sq inch port area per cube - tune between 36-41 hz
HDC312 - 3.0 cube net with 18 sq inch port area per cube - tune between 34-39 hz
HDC315 - 5.0 cube net with 18 sq inch port area per cube - tune between 35-40 hz
HDC318 - 6.5 cube net with 18 sq inch port area per cube - tune between 33-38 hz
2k input power
HDC310 - 1.5 cube net with 17 sq inch port area per cube - tune between 36-41 hz
HDC312 - 2.5 cube net with 17 sq inch port area per cube - tune between 34-39 hz
HDC315 - 4.0 cube net with 17 sq inch port area per cube - tune between 35-40 hz
HDC318 - 5.5 cube net with 17 sq inch port area per cube - tune between 33-38 hz
HDC3 current version
1k input power
2k input power
HDC310 - 1.25 cube net with 16 sq inch port area per cube - tune between 36-41 hz
HDC312 - 2.25 cube net with 16 sq inch port area per cube - tune between 34-39 hz
HDC315 - 3.75 cube net with 16 sq inch port area per cube - tune between 35-40 hz
HDC318 - 5.25 cube net with 16 sq inch port area per cube - tune between 33-38 hz
HDC4 old version (soft suspension)
2k input power
HDC412 - 2.75 cube net with 18 sq inch port area per cube - tune between 34-39 hz
HDC415 - 4.5 cube net with 18 sq inch port area per cube - tune between 35-40 hz
HDC418 - 6.0 cube net with 18 sq inch port area per cube - tune between 33-38 hz
4k input power
HDC412 - 2.25 cube net with 17 sq inch port area per cube - tune between 34-39 hz
HDC415 - 3.5 cube net with 17 sq inch port area per cube - tune between 35-40 hz
HDC418 - 5.25 cube net with 17 sq inch port area per cube - tune between 33-38 hz
HDC4 current version (stiff suspension)
2k input power
HDC412 - 3.0 cube net with 18 sq inch port area per cube - tune between 34-39 hz
HDC415 - 5.0 cube net with 18 sq inch port area per cube - tune between 35-40 hz
HDC418 - 6.5 cube net with 18 sq inch port area per cube - tune between 33-38 hz
4k input power
HDC415 - 3.75 cube net with 17 sq inch port area per cube - tune between 35-40 hz
HDC418 - 5.5 cube net with 17 sq inch port area per cube - tune between 33-38 hz
You will notice the HDC3 and HDC4 like the same tuning based on power and suspension. I have built multiple boxes with different tuning to test how these really performed and these were from my notes on what they really like to get loud. Hope this is helpful.
SoundQubed Woofer Displacement
8" 10" 12" 15" 18"
HDS200 -0.06 0.06 0.07 0.11 -
HDS300 - 0.07 - 0.09 - 0.13 -
HDC3 - 0.11 - 0.13 - 0.17 - 0.23
HDC4 - - 0.19 - 0.25 - 0.33
