Wouldnt need an answer if you would have done it right the first time with a real harness.finally someone who found the answer!! thankyou! i will give it a try and next time use a harness.
Your harness is just as good as buying one. I would recommend soldering the joints and using shrink insulation as well. If you have the proper wire matching, you will be good.if the wires form my truck are going to the correct wires on the deck shouldn't that work? i will go get a wiring harness but i dont see how it will fix the issue.
He didn't make it.Your harness is just as good as buying one. I would recommend soldering the joints and using shrink insulation as well. If you have the proper wire matching, you will be good.
