Boss deck has power but won't turn on.
justwantanswers
I have a 2004 Ford Ranger and i am upgrading my factory deck but have hit a few problems. yes i did push the on/off button and yes it is connected to the wire connecting it to the battery but for some reason it still wont turn on. I know it has power because the power light is red but no matter what i do nothing works. i have tried grounding the parking break wire but that didnt do anything either. my current wiring connections are (from the new deck to old leads) Red to main power wire, Yellow to illumination (interior lights) wire, and ground to Black ground wire. Other than the parking break these are the only wires i can think of that would be the problem. please help!
Sounds like he did it the hard way, but it should still work. All those harnesses do is make it easier to connect the right wires together. There's no problem if you know exactly which wire does what, and connect them that way....
your wires are wrong.
Battery WHITE/YELLOW (+) RADIO HARNESS yellow wire from your radio goes here
Accesory WHITE/RED (+) RADIO HARNESS red wire from radio goes here
Ground BLACK (-) RADIO HARNESS ground wire/black wire goes here
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
| RADIO 12V|lt. green/purple |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/black |+ |radio |
| RADIO ILLUMINATE|lt. blue/red(dimmer)|+ |radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |radio |
| RF SPEAKER|wht/lt grn - grn/org| |radio |
| LR SPEAKER|gry/lt blu - tan/yel| |radio |
| RR SPEAKER|org/red - brn/pnk | |radio
justwantanswers
justwantanswers
Tucson
mahc
