Boss deck has power but won't turn on.
I have wiring diagrams for any vehicle made from 1954 to 2009 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
fords are the worst some of them in the mid 90's to 2002 have upto 7 dif wiring schemes....real PITA when doing alarms lolz
if the wires form my truck are going to the correct wires on the deck shouldn't that work? i will go get a wiring harness but i dont see how it will fix the issue.
Your harness is just as good as buying one. I would recommend soldering the joints and using shrink insulation as well. If you have the proper wire matching, you will be good.
justwantanswers
Junior Member
justwantanswers
Tucson
mahc
