boss audio 12'' subs
i know the amp yont push 1200 i just want a sub capable of over 1200 watts.
i bought that amp before i came to these fourms. and i had no idea about car audio then
had it a long time,
here is all the info on it ..
amp XM-2002GTRwallmart
wallmart
1200 W peak output
two channel bridgeable car amplifier
built-in cooling ventilation (keeps your amp cool at all times and makes sure it does not overheat)
200 watts RMS x 2 @ 4 ohms
250 watts RMS x 2 @ 2 ohms
500 watts RMS x 1 bridged @ 4 ohms
high level sensing power on the circuitry
variable low-pass filter (50-300 Hz at 12 dB per octave)
bass boost (10 dB @ 40 Hz)
Class A/B 2 channel bridgeable car amp
Tri-way capable
MOS-FET output stage and power supply
C--E--A-2006 compliant
preamp- and speaker-level inputs
preamp outputs
15-7/8"W x 2-1/4"H x 10 7/8" D
Signal to noise ratio (dB): 100
Frequency Response (Hz): 5 - 50k
Input Level Range (V) Line level input: 0.3 - 6
Input Level Range (V) Speaker level input: 1.2 - 12
Operating Voltage (V): 10.5 - 16
built and high level inputs to install your amplifier to a factory stereo
built-in bass boost control
Those outlaws are alright, i heard a pair on 1200w rms ported. They didnt have good sound qaulity, i would say they are lower power handling mofos, thats what they sound like. Oh and your "1200" watt sony maybe does 500 rms.
jeremy.vaughn
jeremy.vaughn
marion county AL
n2audio
