boss audio 12'' subs
i know the amp yont push 1200 i just want a sub capable of over 1200 watts.
i bought that amp before i came to these fourms. and i had no idea about car audio then
had it a long time,
here is all the info on it ..
amp XM-2002GTRwallmart
wallmart
1200 W peak output
two channel bridgeable car amplifier
built-in cooling ventilation (keeps your amp cool at all times and makes sure it does not overheat)
200 watts RMS x 2 @ 4 ohms
250 watts RMS x 2 @ 2 ohms
500 watts RMS x 1 bridged @ 4 ohms
high level sensing power on the circuitry
variable low-pass filter (50-300 Hz at 12 dB per octave)
bass boost (10 dB @ 40 Hz)
Class A/B 2 channel bridgeable car amp
Tri-way capable
MOS-FET output stage and power supply
C--E--A-2006 compliant
preamp- and speaker-level inputs
preamp outputs
15-7/8"W x 2-1/4"H x 10 7/8" D
Signal to noise ratio (dB): 100
Frequency Response (Hz): 5 - 50k
Input Level Range (V) Line level input: 0.3 - 6
Input Level Range (V) Speaker level input: 1.2 - 12
Operating Voltage (V): 10.5 - 16
built and high level inputs to install your amplifier to a factory stereo
built-in bass boost control
Those outlaws are alright, i heard a pair on 1200w rms ported. They didnt have good sound qaulity, i would say they are lower power handling mofos, thats what they sound like. Oh and your "1200" watt sony maybe does 500 rms.
jeremy.vaughn
jeremy.vaughn
marion county AL
n2audio
BP1Fanatic
BP1Fanatic
