Boss amps
What about Pyramid or Power acoustik. Also Lanzer and audioban?
Out of all the brands you mentioned I'd go with the MA amp. Lanzar 2nd, forget the rest.
power acoustik has some great amps in the mono line from what i hear...example the A1800db (my next amp).
we carry the boss amp at my work
it's .5 ohm stable, and puts out 1800 on the bench at 14.1volts into a .5 ohm load
so yeah : )
boss amps are great for the buck
dont talk about products you've never used should be a unianimous rule on any forum, and in life.
power acoustic isn't too bad..
power acoustic = spl, so if you've used SPL amps, youknow what to expect out of power acoustic.
There's two different companies that supercolts may be referring to with those initials 'MA'
There is MA Audio...which build some nice amps and they also build some entry-level garbage from what I have seen/heard around my hometown.
There is also Massive Audio, which the original poster asked about when he posted the MA in the first place. I have no direct or indirect experience with any of their products so I cannot comment on whether or not their products are worth buying.
Boss and Pyramid I wouldn't recommend to anyone. They don't do anywhere near claimed output levels and I've yet to see anyone raving about the reliability of any of their gear.
Personally I wouldn't recommend Lanzar but I've seen more than a few remarks about one or two different series of Lanzars (I seem to recall the Vibe series mentioned somewhat often?) being decent for the money. Maybe someone with a bit more experience with Lanzar products will be along shortly.
Audiobahn makes okay stuff, I suppose. You'll find they aren't particularly popular on this forum as well as many others due to Audiobahn seemingly spending the lion's share of their R & D budgets on applying the most "BLINGAGE" to their products rather than investing those funds into actually producing a solid piece of audio equipment. IMHO your money is better spent elsewhere.
I've never used any Power Acoustik gear myself but they seem to have a pretty loyal following. The general consensus seems to be big, fairly reliable wattage for not huge amounts of $$$. I reckon they might be worth a look.
If you're looking for some cheap, reliable amps look to Profile. They're my "goto" amplifier when I need some reliable watts for little cash. You can get some of their gear off of their website direct pretty durn cheap and even paying retail through Crutchfield won't break the bank. I've owned several in the past and loved them all. I'd recommend them to anyone on a budget.
supercolts99
supercolts99
Pittsburgh Pa
mikescanlon
