I'd throw some fiberglass resin to make sure it's not gonna soak up water.Question.. I eventually want a tonnaue (spelling) cover, but I'm wondering.. If I build the box from mdf, then hit it with some sealer of some sort, then I'm going to get some DIY bedliner and brush a few layers of that on the whole bed plus the box, that should be good if it rains right? Amps will be in the cabin so that's not an issue, and I'm going to bolt the box through the bed with a ton of bolts so it won't be able to be lifted.
Has anyone done this?
No? Why would you?question: do you have to do anything to the tonneau cover? Like deadening or anything?
Ah i see... Good luck with 15's... You'll need like a 6th order series.. Like the one guy running the 8 or 6 DC lvl4 15's
Just checking, im trying to get as much info as I can get so I can eventually do a blow through. I still owe about $10k on the truck so I might wait til I pay it off first.No? Why would you?
I need to talk to you dude.. ygpm4 12s in a 4th order and be done.
You could fit 12 12s, but you would need like 74" depth for a sideways clam. And thats with all single 3/4" wood. Would need to be braced like crazy.
Just saying 15's are hard to make fit... I like to fit the woofers depending on how tall I can cut the blowthrough.. I had 15's but it was a pain. I'd rather have my 12's.ok not sure what that is, but i figured do two subs on each side facing each other so 2 subs on the driver side facing the passanger side and 2 on the passanger facing the driver side, and port comming from the back ported into the place where the subs are kinda like a pressure chamber or w/e its called. what exactly is a 6th order series.
and why do us say good luck with 15's should i just go with 6 12's or what or maybe even 8 12's if i can squeeze them in there
From expiernce I will vouch and say dont use the bedliner as the only thing to "waterproof" your box... That shit sucks for waterproofing. I resin every box I do and never had problems. Even if you ever have to take off the cover you know its going to be ok if it gets wet.Question.. I eventually want a tonnaue (spelling) cover, but I'm wondering.. If I build the box from mdf, then hit it with some sealer of some sort, then I'm going to get some DIY bedliner and brush a few layers of that on the whole bed plus the box, that should be good if it rains right? Amps will be in the cabin so that's not an issue, and I'm going to bolt the box through the bed with a ton of bolts so it won't be able to be lifted.
