big PROBLEM!
kottonmouth
my Dynasty is a dynasty
459
Ubly, MI
heres the problem. i persoally think my amp is blown, but i want to make sure. heres the deal: my amp started to quit on me and the protection light would go on. i took out my subs and checked my wiring. i hooked my amp and subs back up and turned it on and there was nothing except a buzz coming out of my subs. could my subs be blown? or is it the amp?
i have a Visonik V800XD (mono amp) with 2 12" JBL GT's hooked up at 2 ohms. I know its not my ground. All the wiring is secure and good. There is no sound coming out of my subs except for a a buzz which isnt very loud at all. Should I take a voltage tester to my amp and check all the connections and then take another amp and hook them up to my subs to see if they work.
Yeah I would definitely test your voltage, I believe the amp is not giving out any power, you mentioned your protection light came on, turn the gains down all the way, or try wiring to a 4-ohm load, if it works, then your amp has about had it. I had the same problem with an amp. If it doesn't work, check your subs, just to be on the safe side.
Easy enough to check the coils with a DMM. Though described. Sounds like its trashed. Time for a replacement IMHO
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
kottonmouth
kottonmouth
Ubly, MI
kottonmouth
    May 18, 2024
    May 16, 2024
