big 3 or better battery?
Both! but if not both you would be ok with the stock electrical and having a larger reserve with a better battery. With the larger reserve your amp should run better and you should be able to hit more power hungry notes better, like those awesome lows. When i started my newest system, i just had stock electrical, 4 gauge ofc front to back, little wet cell bat under the hood, and the wet cell bat from my car that blew up, running an aq1200 and hdc3 15 wired at 1 ohm......it was good but lacked in long bass note output. when i upgraded to a kinetic hc2400 in the back i noticed a great improvement with those long bass notes. the big 3 just helps keep up the re-charge as you dis-charge, so it will be fine until u can or want to do the big 3 with just a better agm bat.
Good Luck tho
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
548
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
RicksI30
vlusardi
    Apr 27, 2024
    Apr 27, 2024
