Big 3 CCA vs OFC vc Tinned OFC
  • 6
I wouldn't use CCA on the big 3 just because Aluminum doesn't hold up to the weather quite as well.
Done the right way the cable strands shouldn't be exposed to the elements. Crimp the terminals, solder them, heat shrink the joint of the terminal to the jacket, then cover it all to mimic the factory wire runs. Paint over the connection to the engine or frame to keep oxygen out of the joint there too. If you're going to do all that then OFC would naturally be used as well.
Exactly, the Big 3 is kind of a more permanent change, so when you start to get the wear and tear on the jacket and shrink wrap and get little holes starting, you don't want the wire inside to go bad.
just get one of the kits already done , just needs to be bolted on .i do sell them .ends are crimped and soldered ,heat shrinked to .3 pieces cut to your length specs .
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
sbarber82
sbarber82
Vegas baby
mylows10
    May 31, 2024
    May 24, 2024
