Best Amp for money!?!?! HELP!
T-BirdK
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Help I'm only 15 and I have a limited budget I need an amp thats decent power with low heat I'm new to the Car system stuff since I am recently able to drive and just bought my first car (1988 Ford T-Bird 3.8l v6) If you can tell me a decent amp and/or sub and what ever else i need id be very thankful i'm a newbie to the forum but I am hoping to learn a lot more I already have a reciever (have to check on what it is) lookin at a price around 300-400 dollars for all equipment minus the reciever. Please help!!
Is this a good amp to impress my friends or at lease sound pretty nice? and if so what other things do i need to go with it?
KENWOOD 600 WATT MULTI-CHANNEL AMP
600 WATT X1 2 CHANNEL BRIDGEABLE MOSFET AMPLIFIER. BUILT IN CROSSOVER THAT IS COMPLETELY ADJUSTABLE, COOLING FAN, SWITCHABLE 2 OHM STABLE, BALANCE INPUT CHANGEOVER, LOW PASS FILTER, POWER INDICATOR LED, LOW PASS FREQUENCY CONTROL, INPUT SENSITIVITY CONTROL, HIGH OR LOW LEVEL INPUTS,
FREQ. RESP 5HZ TO 50K HZ
SIGNAL TO NOISE BETTER THAN 105 DB
I feel like im talking to myself but I keep reading the forums? would the amp i listed above go with a 12" Kicker XPL 4ohm sub woofer? come on anyone LEAVE tips im desperate
depending on the subs, for the price you could go with coustic, profile. If you want to get real lazy try a vibe, many people hate this amp, but it's a well built amp.
look for a 4 channel amp, then use 2 channels for your front speakers, and bridge the reminaing two for your subs.
here are 3 setups
zx6400 (hifonics) = onlinecarstereo.com
85x4 120x4 350x2 so u can do = 85x2+350x1 (alpine type r comps & 1 shiva)
orion 8004 = onlinecarstereo.com
100x4 200x4 400x2 so u can do 100x2+400x1
(cdts comps & 2 diamond audio m3's 12s)
x603 =sounddomain.com
75x2+ 300x1
(crystal comp's & 1 12jlw3v2d2)
Hey man, got a great deal for ya.
http://forums.caraudio.com/vb/showthread.php?t=53051
check that out, MUCH better than that kenwood. Great amp will give 450watts rms to any sub @2ohms. Really great deal, got references if needed. All you would need then is some front speakers, sub, and speaker amp.
check out:
speakers: front go with 6.5" coaxials for ur budget.. http://www.thezeb.com cdt-cl6x's
sub: one 12" eD Kx http://www.edesignaudio.com dual 2ohm
sub amp: the one in thread
speaker amp: us acoustics usx2050 http://www.thezeb.com
box: http://www.gnomeaudio.com Get Donn to build you a custom box about 2 cubes ported @30hz that thing will be wangin.
there you go, nice system for cheap
Wiring kit: Scosche EFX two amp 4 guage wiring kit form Walmart
Well rounded system for under $400. Includes everything u need. peace
NG
where'd this guy go? he's all wet for an answer right away, and now he doesn't post... oh well. i'm gonna do what most folks do and suggest what i have, 'cause that's what most of my experience is based on:
Profile amp, run in tri-mode (2 front speakers, and a sub bridged on the other 2 channels). then get an Alpine, or Fusion, or Elemental Designs sub. maybe 1 12" would be okay. then some Wal Mart wiring, a couple CDTs from thezeb.com, and "Safety Dance" on cd.. you're all set.
abe m.
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
10K
T-BirdK
T-BirdK
Lawrenceville, GA
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
