Battery voltage 11.9 - 12.0, car still starts? WTF?
I just had the battery checked last week at Autozone. They said it was fine. It is a marine battery but they said it makes no difference. I'm totally amazed my car is still starting with 11.6 volts in the battery. I did everything right. Big 3 done with 2/0 gauge, lead free soldered, grounds sanded, stock wires left alone, pure cooper terminals, etc.
yeah see that whats weird, the car shouldnt start at 11.6 volts. Makes me think that you're not getting an accurate reading for some reason. only thing i could possibly think it could be.
That is what I first thought too. Then I tried my DMM on 3 other car batteries and then read normal. Maybe I have a bad ground? I crimped and soldered everything... I can't possibly have a loose connection can I?
When you are reading your voltage, are you connecting your dmm directly to the battery post?
Where are you located in Nebraska? Maybe I could take a look at it and help you out. Im in Lincoln.
North Platte //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif A little too far away.
OP, you are an idiot. The starter will turn over with as little as 9-10volts.............as long as there is adequate amperage supplied. Go have the charging system checked dumbazz.
hey my truck has the same problem, i have 4 batteries with a 300 alt and is reading around 11.0v with the truck on its about 12.3v idk wtf is going on!
Why does anyone even help this scammer? And how is he still on the site? Got an IPcheck, and seems you and CarAudioNewbie share the same IP. Hmmmm, sounds odd to me. And you live in Nebraska, how is that so?
Oh stfu mikey, he's having a problem, and this is what this site is for. Secondly, you don't have anything to run an Ip check you liar.
Sir Swish
Sir Swish
Nebraska
MikeyF
ThxOne
    May 29, 2026
tyler0508
    May 27, 2026
