battery or altenator???
New battery won't do much for you, when your car is running all the amps are drawn from the Alternator. Big 3 would be the first thing to do then if you are still seeing voltage drops you'll need a HO Alternator.
how many amps is you stock Alt? and how many watts for your system?
Big three in the engine bay... (make very good grounds).
-then-
Battery (electrical draw greater then the amp output will draw from the batts).
-then-
Alt
-then-
Extra batts.
-Nick
im not sure on the alt. specs....my amp is a jbl 1200.1 pushing a 12' alpine xtype
Those Jbl's are power hogz. I hooked my friends JBL up to my system to see if it worked, and every single light in and on my car dimmed like a theater just b4 the movie. I hooked my Brutus 1500D back up, and no problems. Only minor dimming at stop lights.
Btw yall, what exactly is the big 3? I have 4 guage power and ground, what other wires need to be bigger?
If my current alt is 100 amps and I am installing a Hifonics BX1500D would I need a high output alt?. I hooked up a JL 500/1 and I had a horrible dimming problem.
I have a stock 125a alternator, and I only get minor dimming at stop lights, and no problems in the day time. I'd say if a 500 watt amp dimmed your lights, an amp that puts out approximately 3 times more than that will definately be worse. Don't ya think so?
What is the typical size guage wire that is going from alternator to battery in a stock electrical system?
And is that it, just upgrade the wire from the battery to the alt?
customlt1
customlt1
buffalo,ny
Nikuk
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
