AVIC-D3 not fitting
BigPimpin18
I have a 1997 Acura 2.2CL and I just bought an AVIC-D3 and now it doesn't fit. I have the double din kit and all that. it feels like it's too deep for my car. Has anyone installed a double din in this car and have any tricks they want to share with me. Or if anyone has had a similar problem.
Post a pic of your dash inside your car. If you car has a normal double din, then the AVIC d3 should fit in with out a kit. You should only need the two side pieces to mount with the bracket already on the D3.
is there a little brack in the back of the dash in like the middle i know some vehicles have a little piece that is there for the oem hu and it needs to be cut off for new hus to fit in
You right, I forgot about that also, I had to break that part off in order to get my Avic to fit. That was a biatch also.
Sorry, my header could have been more specific. Anyway, I might be the only one, but I want to get rid of the large AV source window on the main...
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
914
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
BigPimpin18
BigPimpin18
Seattle, WA
Qbenjamin
