AudioQue 2200D or Planet Audio 2400.1
The BB2400.1's are nice amplifiers, but you would probably see more power out of the AQ2200, but it would be marginal , really would just depend on the price difference, both are soild amplifiers
Only thing I don't like about the pa 2400.1 is that they dont have a CEA compliant approval on it so you never know if it actually pushes out rated rms.
But, I have seen the BB1250.1 in action, actually 8 of them paired with 8 re xxx 12" subs. You are probably familiar with this truck/setup im about to link from about 2-3 years back. Audio Innovations in Fresno, Cali built this setup.
It gets down but remember he has a lot of amps and subs lol in a blowthru. Some guys can take any amp and make it loud though its all install dependent.
I know one cheap amp that actually pushes out what it advertises. Look at an audiopipe 3000, and better yet look at some amp guts and you will be impressed. I am probably going to buy one as they are the best dollar per watt you can get now. Good bang for your buck. They are 2ohm stable though but do 3K @2ohms. Don't run it below that or you'll have probs.
It's called clamping:rolleyes:
No you will not have problems. You only run into problems when your electrical is garbage. I have ran multiple AP 3000's @ 1.5 daily........
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
KJThaDon
KJThaDon
Westland. Michigan
Annnarbor84
    May 24, 2024
    May 23, 2024
