Ascendant Audio Ava, 04 Dodge Stratus R/T Coupe Build...56k beware
Looks great man, gettin' there.
Keep us updated with pics on every step until the finished product, I would like to see this baby grow into a full grown adult.
Make a father proud!
If you don't mind.
When you're attempting an install of this magnitude, do you have another car as your daily driver? Or do you use this one? Is this only on weekends? How are you approaching this?
Weekends are ususally when I have enough time to work, but I also drive a work truck, it's the companies, but I take it home.
Dang, I wish I had a work truck and a driveway //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif//content.invisioncic.com/y282845/emoticons/bowdown.gif.b85b23b82970bd22fb6b549c3392f016.gif
3/4 Of a gallon of resin later...did a layer, but not the sides yet..got too dark, and a lil colder...
Most of that isn't air bubbles, there isn't many, but ripples in the first layer of fleece, and buldges of foam...doesn't need to be neat, isn't going to be seen, just needs to be strong.
Shot of the engine bay with the positive alt wire, and two grounds going to the battery, and there is another ground fromt he battery to the chassis to make the big four //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif (2 grounds on the engine block/1 by the alternator)Oh, btw the ends where crimped 0 gauge 3/8" ring terminals, and soldered.
You can see the stock wiring tied into the system here:
Thanks for looking, hopefully I'll get wood work, and fiberglass work done soon!
In the mean time, you can check out my car domain (all old though):
http://www.cardomain.com/ride/804181
insane cleanness
how many foot did it took you for all the engine wire
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
93
38
Rawr-DQ
!!!!Vote Third Party!!!!
Rawr-DQ
Fort Myers, FL Posts:____________31,337,666,999
Rawr-DQ
    May 24, 2024
    May 23, 2024
