AQ2200, What sub/subs ? l7's , BTL, ? want reallll low
I don't know who told you that because I do it and see it done all the time. There is a roll off, yes, but it's not a direct drop off to being free aired.
It's not a perfect slice, but it's a very fast roll off of a cliff. A box tuned to 39 Hz will still play a little 35 Hz, but by the time it gets down to 20-25 Hz it's all being cancelled out.
The lower freq's that are longer than the port length are being free aired.
Good article on subsonic filters that also explains freq's below a ports tunning frequency.
Subsonic Filtering MATTERS!By AdireRulesForever
SS filters are a good insurance policy when using ported subs. If low frequency (signals below PTF) are present in the audio content, the sub "unloads" (cone becomes unstable) and goes into cardiac arrest mode. Basically, we want to filter out as much audio signal power below PTF as possible to prevent woofer destruction.
For example:
We talk about SPL in dB or decibles. This is a unit of measure as to how much acoustic output an audio system can reproduce. We know that audio signals are electrical impulses from a source like a HU or amplifier. The amout of voltage it can put out, can be converted to dB's of sound pressure level. Hense SPL. The speaker (transducer) converts this electrical energy into sound waves. How much sound we hear out of that speaker is generally expressed as SPL in dB. (not voltage) Did I lose you yet?
Now, with ported sub applications, we know there is a lot of bass energy in todays' music. Some lows we can hear very well. Very low frequencies,
(subsonics) are signals present, but we cannot hear them. We may feel them at a theater with movies like Volcano, Jurrasic Park and such... but we really cannot hear them. The subwoofers used in these applications are massive and designed to reproduce bass below human hearing. Best most of us can hear is ~25-30 Hz. Bolow that, it's mostly below our hearing ability...
but we can feel it.
OK, back to business on filters. Say you have a sub and amp. The amp is say 300 RMS and the sub is moderately efficient. (89 dB of SPL at 1 watt, 1 meter away) The sub will reproduce bass well in sealed enclosures and net about 125 dB of SPL in bass range of 40-150 Hz. As the sub gets signals below ~ 40 Hz, the dB # will naturally rolloff at a predictable rate. (slope) The term used in audio is -X dB/octave. In the case of a sealed box design, that slope is -0dB at 40 Hz., -6dB loss of SPL at 20 Hz., -12dB at 10 Hz. (these are octaves.. 40,20 &10 Hz.)
In ported designs, the Port Tuning Frequency (PTF) determines how low the sub will play and still be distortion free. When porting, we get a nice passive peak in bass near the PTF. That peak is about +3dB more than a sealed enclosure will deliver with same sub and same power input. So now, you have +128 dB of output VS the +125 dB we mentioned earlier.
Near the PTF, the cone produces very little audio. The sound comes from the port. The cone does not move very much near PTF as the back pressure in the enclosure is being released into the port. That means the lack of cone movement, reduces cooling of the voice coils. This is where a lot of subs get fried. Not much movement and loads of power being dissapated in the form of heat. That's what fries a sub coil.
Below PTF, the cone motion returns, but there is so little backpressure in the box, it cannot control the cone movements. (unloading) Basically, this acts like there is no enclosure at all. (a "free air") sub is the result. With no control over the cone movement, the sub goes spastic and will often jump the gap or the coil bottoms out. Again, the result is a damaged sub.
When we use a SS filter, the filter will remove a goodly portion of sound energy that would normally pass to the woofer. The larger the slope of the filter, the better. Less watts of power (SPL) to the sub, below PTF is how we protect expensive woofers. The most efficient way to do this, is prior to amplification. That helps the amp as it does not waste large amounts of power, trying to amplify signals below PTF. In car audio, we don't get much music content below ~35-40 Hz. If PTF is say 40 Hz., we want to filter out as much signal content as possible, as we approach PTF. This is where good filtering is needed.
Let's say a sub is getting 300 watts of signal at 40 Hz. That's pretty loud stuff. Now, insert a 40 Hz SSF, 12dB/octave and the output watts will drop to (~20 watts) flowing to the sub at 20 Hz. That's safe for the sub to dissapate heat in that range. A 40 Hz SSF, 18dB/octave slope will lower the power to sub even more. Here, the sub is getting about 4.5 watts at 20 Hz. The basic line of designing a good filter, is to know that for each 3dB of sound we filter, it drops the watts input to the driver by 50%.
Here's a chart:
dB Slope/Octave Output (Watts)
0dB (no filtering) 300 watts @ 40 Hz
-3dB 150 watts @ 20 Hz
-6dB 75 watts @ 20 Hz
-9dB 37.5 watts @ 20 Hz
-12dB 18.75 watts @ 20 Hz
-15dB 9.38 watts @ 20 Hz
-18dB 4.7 watts @ 20 Hz
See how that works? It's logrithmic, not linear.
Hope this helps some of you as you look at Ported enclosure designs.
Swez
PS Most audio sales people and installers are just that.... installers and sellers. This is design and engineering type stuff. Don't expect them to know it, unless they have studied it in depth. Am not an Expert in this area, but have studied it a while now. Hopefully this presentation of a very complex subject, is simple enough to learn and use.
http://www.caraudio911.com/
Your AQ's will get low. If it were me I'd tune the box lower. I'd also Keep the 2200's and call DJ and ask about re-coning one to a 15 or 18 and mod it to your specifications. Usually its cheaper to re-cone then buy a new sub.
Just my opinion.
Harleyfx69
audio n00b
Harleyfx69
arizona
mlstrass
