AQ SDC2.5 10 isnt loud...
not_loud_enough
So i got my Aq SDC2.5 10 D4 on Friday and ive broken it in all weekend free air with a 40hz sine wave and 1" excursion. i put it in its box today and it isn't that loud inside my car? i have a honda del sol and i made a trapezoidal box to fit behind the seats sub is facing forwards port to the side.
Its hooked up to a Aq 1200d at 2 ohms should be getting around 800 watts
My port might be f****** up...
The box is 1.8 cubes
3" Top depth
12" Botttom depth
33" width
18" height
1 - 4 inch pvc 13 inches long inside box should be around 36-37 hz (.08 displacement)
and the sub is probably .1 displacement
someone help me out im disappointed....
Make sure theres no leaks.
You box size seems a little big, after displacements its about 1.6 cu/ft, AQ doesnt even list box recommendations on their site- wtf.
They do list box recommendations, you just have to look harder.
They recommend 1.2-1.5 after displacments for the 10. I would also agree with previous posts, the box seems like it is the culprit. Either leaks, or poor desgn, or both
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
not_loud_enough
not_loud_enough
West Milford, NJ
not_loud_enough
