AQ HDC3 12" vs Type-r
the aq wants more power but it will do okay on 1300 in the right box. they do okay with the lows but the lowest you want to tune the aq is to like 37. mine tuned to 38 hit the lows pretty good for the tuning
Louder on the mic? The AQ, but only if you raise the tuning as said. Louder to your ear? The R. Honestly, they are not comparable subwoofers at all.
all day long the aq will get louder. 450 more watts than the type r. the aq is geared towards flat out getting loud compared to the type r. there is no comparison. do some research and you will see. I hit a 138.7 off one aq hdc3 12 in a honda accord 2002 off a single elemental designs nine.1 (1200rms), 4 gauge wire and stock electrical. this was also db drag style and off music. get the aq bro
I've had both, and pushed both to the limits.
AQ cost twice as much as R for a reason.
R is a great beater sub no doubt, but just out classed here.
That being said, I'd bet they'd be close in this battle.
I'd tune AQ at least to 35ish, you can leave R there and it'll **** the lows.
AQ doesn't need low tuning too go down low.
That's my 2 cents.
either set up has the potential to get loud. For a daily beater I'd take the AQ as every R set up I've heard has not sounded very good at all.
HDC and a 2200 would be a nice combo...but the R and 850watts would work also.
HAHA. I love the responses. Has anyone really had a type R and a hdc3 to compare? If you only knew... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I have an HDC 10 sitting in my closet and I've designed probably 15-20 type-r enclosures. So yes, I do know.
adio25
adio25
Wausau, WI
PV Audio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
