Another new guy trying to do things right - 1966 impala quality system
  • 4
Okay that makes sense.... how much for the amp? and how big is it?
If i wanted to keep the kappa amp, just cause its pretty and seems to do a decent job (I have been using a boss 420w max amp i bought in 1998 up till this Christmas when i found the kappa one re-manufactured, I hooked it up and it seems like i have bass to spare with the kappa one.) Do you have any 4 channel solutions? or would i be way better off going to the 5? I haven't commented on my electrical system, but i am running dual battery's with an isolator and a 130w alternator and 0gauge cable.
Also thoughts on just using 6.5 midbass/midrange speakers instead of the components? just something I've been kicking around in my head.
The amp is normally $369 shipped. But I need it gone. So $320 shipped. Also is got that route with the components. Try to do a 3 way set up there sounds like the electrical is go with the exception of a big 3 kit. The amp is pretty efficient. So you should be good. If you wanted a 4 channel instead. I'd go with an arc audio. But it would cost about the same as my amp new. Also the amp is 13x6x2
Okay.. So with your advice and some research, I decided to go with a 3 way comp setup for the front stage.. This way I can get away with one amp and simplify the system. going to put the 4" kappas coaxials on eBay, they are NIB... For now I'm going to wait on an amp... But I need to get a 3 way component set, I can swing around 300-350 for a 3-way set... What are my best options? I've found the cdt cl series and the hertz sets on eBay in that range... Any used options?
Thank you all... Just picked up an Arc Audio 4 channel... Considering the CDT Cl series , DLS Reference series or the Hertz ESK for the 3-way comps, unless i can find a used set for around 300-350.
All nice sets. And I carry all if them a decent 3 way set tho would be $400 new
You think the 4x 80w RMS at 4ohm will be sufficient for the CDT set? I noticed the DLS brand is less power hungry, But I am really leaning towards the CDT CL-6e42 if they will work decent with that rms wattage.
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
801
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
944
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Impalow
Impalow
Northeast Ohio
Impalow
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
