Amp protection cuts out @ 3/4 volume. Clipping or wiring?
Ardinger
Hello,
What is clipping versus wires grounding out? I had a package installed by someone else that are 2 / 10" subs @ 600watts RMS, and the amp is designed for 800 watts rms @ 1 ohm or 600 watts rms @ 2 ohm. So the end result is the amp cutting in and out of protection mode if I turn the volume higher than around 3/4 of the head unit's capability.
So can anyone tell me if I should start by checking the sub speakers are wired parallel or is it more likely that it is the wiring to the amp?
Hello,
I've had that happen, but it was a not enough electrical problem. My electrical couldn't support the amp so it went into protection when I'd turn it up
So don't turn it up that loud. You are definitely over-driving your amp and you will probably break it if you don't dial the gain down or take care with your volume control.
Ok thank you, I'll check where the remote wire is connected and get back to you.
843
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
5K
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Ardinger
Ardinger
hispls
    Apr 28, 2024
    Apr 28, 2024
