Did I pick the right parts? - adding a sub to a factory system
silverh20
I have a 2011 BMW 550i that has an upgraded "surround sound" stereo option from the factory. Everything is decent except the bass.
I bought a Kicker L7 12" 4ohm DVC sub and plan to wire it up to my Alphasonik PMA600HC dual channel amp in bridge mode for 950watt RMS @ 4ohm.
I read an install guide for my car and someone needed a Line Output Converter for their 2 subs. I'm using just one and this is the amp config I plan on using.
Is this right then to get this LOC? https://www.amazon.com/dp/B08GH74SQT/?tag=caraudiocom-20
Thats a quality piece it should work fine
This is not going to be possible. You'd need a 2 ohm dvc to get 4 ohm at the amp.
Also make sure you connect the LOC to a full range signal. Some factory systems have a safety attenuation bs feature that decrease the bass at high volume.
silverh20
silverh20
ft lauderdale
mahc
