Amp protection cuts out @ 3/4 volume. Clipping or wiring?
Ardinger
CarAudio.com Newbie
Hello,
What is clipping versus wires grounding out? I had a package installed by someone else that are 2 / 10" subs @ 600watts RMS, and the amp is designed for 800 watts rms @ 1 ohm or 600 watts rms @ 2 ohm. So the end result is the amp cutting in and out of protection mode if I turn the volume higher than around 3/4 of the head unit's capability.
So can anyone tell me if I should start by checking the sub speakers are wired parallel or is it more likely that it is the wiring to the amp?
Hello,
I've had that happen, but it was a not enough electrical problem. My electrical couldn't support the amp so it went into protection when I'd turn it up
Ardinger
CarAudio.com Newbie
Ardinger
hispls
