Amp in protect
  • 2
bostonwhaler23
Lately my amp has been doing this weird thing. My system is a crunch 1800 watt amp for my 8" skar sub wired at 4 ohms bridged and a dual 400 watt amp for the highs. I amp using a distribution block to distribute power between the two amps. Lately my highs have been working fine, but the amp for the sub randomly goes into protect when I turn on the car (It does this both when the key is turned to accessory and when I have cranked it.) I went through all the wiring and can't find a short. I made sure I had a good ground on bare metal. I tested the volts, around 12 when the key is in accessory, and 13 when the car is cranked. Occasionally I am able to fix the problem by driving some and then stopping the car, turning it off, and cranking it again. Neither the sub or the amp gets very warm. Any ideas as to what the issue might be?
is it possible that the amp is the problem? if you are using a distribution block and your other amp is getting sufficient power and ground, your wiring may be okay. Are you using a distribution block for your grounds also? Curious.
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
bostonwhaler23
bostonwhaler23
Florence, SC
huberoy123
slater
    May 2, 2024
slater
    May 2, 2024
