Amp for 3 subs?
Ericjl
I'm going to get a system with 3 10 inch subs. What is the cheapest way to go about doing an amp? Should i get a 2 channel and a mono? or 3 monos? Or is there a way to hook up a 4 channel? What about a 3 channel, does it exist? Thanks a bunch for your help, just getting started with this, trying to learn the ins and outs. -Eric
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Ericjl
Ericjl
Greensboro, NC
audiolife
    May 24, 2024
    May 23, 2024
