fosgate vs jl vs jbl
  • 3
crakerhead
ok im lookin at gettin two 3500 series dd audio 15's or 2 jl audio w3 15's or perhaps 2 15" fosgate's (prob highest model i can find). these would go into a cherokee. what amp should i run these off of? im thinkin on the jbl 1200.1 to each perhaps (if i get the dd audio) and if i go w/2 jl's then im not sure...thinkin on one fosgate 1000.1 or 1500.1 amp. or should i wait to see the new jl audio 1000.1 amp. i know one guy that has 2 of the jl subs w/a 500.1 amp to each of them. he had 2 in a lexus and it was **** loud but i want louder.
well, if u know what ohm load ur gonna run it at, it would be easier to choose an amp. if u decide to run it at 4 ohms, the fosgate will only put out 750 for the 1500 and 500 for the 1000. if ur gonna run it at 2 ohms, u'll get 1500 and 1000 respectively. the jl will put out 1000 at 1.5-4 or 6 ohms i believe. the jbl is a great amp, nothing wrong with it at all, but not quite up there yet with the fosgate and jl amps. if ur gonna run 2 ohms, i'd suggest the fosgate, anything else, i'd go for the jl. u might need 2 of each depending on what sub u pick too.
If anyone is looking for an awesome sound system for an S550 Mustang here is mine. I took my time installing this new sound system in my 2017...
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
crakerhead
crakerhead
Richmond, VA
SuckMikeHawk23
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
