amp and sub matches that are good
will be running this vertical behind sub box , right behind rear seats. i also will be building a cooling box with 4 4 inch fans, 2 push and 2 pull, they will probably be facing up towards the rear deck, so i have room for adj on the settings of each amp. the abs will probably be screwed to a puce of 1/5 inch plywood or to a piece of 3/4 inch mdf. i dont think its string enough to support the amps and everything by itself.
i think i found a thread that explains it , it just doesnt say about 2 amps, but i think i have the gyst. is it better to have a separate ground for the rear battery, rather than tying it in with the other ground. is it safer?
i have another question.. i have the ct sound ct-150-4D amp, to run front speakers. PowerBass OE-652 are 2 ohm speakers. amp says it can run them. does anyone have any experience with these speakers? i have already done killzmat and foam. am ripping out rear deck speakers as we speak. running wires to rear doors is gonna be a pain. wondering if these will be enough to fill cabin with enough sound. does anyone have any other options or speakers. i have kicker 4 ohm in the front doors now. i am working against the hurricane coming this way. should be here thursday. am losing wed and thurs for appointments. any help is much appreciated. thanks.
watcher6342
CarAudio.com Regular
watcher6342
hortense ga.
Silicon oxide
