Aftermarket HU, Factory Amp, Adding an Aftermarket Amp and Sub Question 07 Wrangler
Adam Lane
CarAudio.com Newbie
2007 Wrangler Infinity Amp
Pioneer HU
The HU is connected to the factory harness, which keeps the factory amp in play. I am trying to pigtail the remote wire from the new aftermarket amp to the remote wire on the HU side, and it is causing a parasitic drain. I have done this in numerous vehicles and never had this issue. Any ideas?
Pioneer HU
When connecting an aftermarket head unit (HU) to a factory amplifier, there are a few things to consider that may help resolve the parasitic drain issue you're experiencing:
1. **Check Your Ground**: Ensure that the ground connection for your aftermarket amplifier is secure and properly grounded. A poor ground can cause excess current draw.
2. **Remote Wire Configuration**: Instead of connecting the remote wire directly from the head unit to your aftermarket amp, consider using a relay to control the power to the new amp. This will isolate the two systems and prevent any back-feeding of current that might cause a drain.
3. **Identify Amp Power Requirements**: Check the power requirements of your aftermarket amp and ensure they do not exceed what your vehicle's electrical system can handle when connected to the factory system.
4. **Inspect Wiring**: Ensure there are no short circuits or damaged wires in the connection that could be causing the drain.
5. **Use a Multimeter**: Measure the current draw from the battery when the vehicle is off, and check to see if there is a significant draw coming from the remote wire or the amplifier. This can help pinpoint the issue.
6. **Consult a Wiring Diagram**: Refer to a wiring diagram specific to your vehicle to ensure proper connections and that you're not inadvertently introducing a circuit that draws power continuously.
If none of these solutions help, it may be beneficial to consult with a professional installer who can provide hands-on assistance.
I like this suggestion. I use it for my amps' cooling fans.
"Remote Wire Configuration**: Instead of connecting the remote wire directly from the head unit to your aftermarket amp, consider using a relay to control the power to the new amp. This will isolate the two systems and prevent any back-feeding of current that might cause a drain."
Thank you, and solid advice. I pulled the remote wire and ran it to my switch panel, and problem solved. I know some people don't like having to manually control amps. I'm going to take your idea and redo the fan on the amp in my son's truck.
Adam Lane
CarAudio.com Newbie
Adam Lane
Dallas
Jimi77
