American made amplifiers
It’s a crowd of people who don’t know any better(SQ snobs) and people that don’t care(Bassheads). Again, it’s all in the application. Basshead stuff is built to be bulletproof. Which makes it a more quality product then some low power “SQ” gear. But the “SQ” gear cost more. That makes no sense.
Good Lord, that may be the dumbest thing I've ever read in this forum. I think my IQ dropped 20 points just from reading it.
How is it dumb? Find a “fancy” SQ branded amp that can handle .15ohm daily while being efficient and compact.
Then find somebody that knows how to tune and install say this is not more important then the brand.
Maybe you don’t know this?
He knows it all, bro. You won't sway his opinion, don't even bother.
How is it dumb? Find a “fancy” SQ branded amp that can handle .15ohm daily while being efficient and compact. Then find somebody that knows how to tune and install say this is not more important then the brand.
You won't find anyone into SQ who is running their amps at a near dead short because they know that the quality of music suffers when an amplifier is asked to perform at such low resistance loads. BTW, your amp isn't very efficient at that load either. Just because a amp will survive at .15 ohm doesn't mean you should run it like that. Efficiency is greatly reduced every time you halve the load the amp 'see's'. But, you probably already knew that, right?
BTW, I notice you aren't running Audiopipe, Lanzar or Pyle amps. Kinda goes against your argument that the amp brand doesn't matter.
---------- Post added at 01:00 AM ---------- Previous post was at 12:59 AM ----------
Yeah, I have quickly become aware of that. Wasting my time I guess.
and here i am still wondering if i should use my PPI PC250 or the Xtant 603X for my front stage //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Have you ever tuned a car? I thought just like you before I started doing it a few times. I quickly figured out the amp used didn’t matter. No amp will fix the natural response of the car or fix resonance in panels.
I’m not saying they do. I’m saying they can. Therefor they are built better. So they should cost more but they don’t.
Do you know why I don’t use cheap amps? Because I still want power.
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
961
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
Muffdogg
Muffdogg
Muncie, Indiana
LosIsATool
    May 12, 2024
Brendon Jenness
    May 11, 2024
