Alex's Silverado
Everyone is always telling you to slow your roll and think things through dummy
Yeah, well... I've got money to blow and it's always burning a hole in my pocket!
My only expenses are gas, food, and other stuff I want to buy right now.
Mis well just get a hooker for a night. I could never waste money like that.
There's an idea.....
Might get my third STD //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I'm probably the most drunk I've veen in an ewhile rightnow, lol.
A couple beers, fireball, and a couple classes of pink Miscoto
Too much power smokes coils, playing below tuning/over excursion breaks triple joints.....just an FYI for the future if you run into problems
I didn't break the triple joint. These Wardens were custom made with extra triple joint support because Evan broke the triple joints on all three of them last year during testing. Just separated the spider from the basket landing spacer. They were fine at that song on lower power and played fine for 15 minutes, so I'd still owe the failure to more power than they could handle
Pitiful.. let this thread die..
I might start a new one when the 8 15's get here
Tearing spider from the landing is playing too far below tuning with too much power. If spider didn't break loose than triple joint would have broken. If they take the power at higher freqs than it's only too much power because you're too far below tuning and lose cone control. Just trying to help you understand as 8 recones would be expensive once the new build is done.
So is the new build going to be as **** as my 10 15's //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Gotcha.
Going to be as what?
Where are your new woofers at? Hasn't it been two weeks?
IA is backed up because of Slam. I'm not going to get to go, unfortunately. I'm in no rush, so I'm not really upset that it's going to take longer. Hopefully I can get some extra decals or something
Tear-down started today
28kw just chillin'
When I was finishing up and had three batteries in parallel, one of the wires slipped and hit the other jumper rail. There was a big pop, but luckily no explosions. They were touching for about 10 seconds before I figured out where it shorted. Melted the heat shrink of a few lugs. One amp was still hooked up to the batteries when this happened. Going to have to test the amp and the affected batteries later. Hopefully no serious damage.
Definitely going to do aluminum bars when I rebuild.
Going to remove, test, and clean all the batteries. No sense in hauling around 2,000 pounds of lead in the back of my truck when my subs are unhooked. I pay for my own gas, and don't want to get 10mpg if I don't have a system playing.
Got a CRUNCH 2 channel to run some "Massive" 6.5" subs in my doors.
Guts:
Not beefy obviously, but they look complicated.
Soundive subs are apparently going to ship this week. I'm going to continue the teardown after I rest for a little bit. It's going to be a progressive thing I work on after work from now on.
I'm hoping to get the new system in and playing by August 10th this year.
Battery bank and sub amps are out
Empty bed besides the speaker wires and power/ground runs. Alternator relay is unplugged and I put the stock belt back on, so the three high output alternators are not being powered on or spun.
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
ChaseinBass
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
