A few questions about subwoofers and amp options...
If you want to save money and get a decent amp, look into the PPI Ion or Black Ice series. PPI makes some good quality budget amps. I have a 650.1 that will drive a 2 ohm load to 650-watts RMS clean and its only around $110.
Good amp brands: Sundown, AmericanBass, JL Audio, JBL, older Rockford Fosgate, SoundStream, certain PPI, DD, Kicker KX series.
Ok so my final options (if you have followed my other posts) are these two setups...
1. Two DVC TS-W3003D4, Ts-a6995r 6x9's and a Pyle Pla4278. Or...
2. Two DVC TS-W3003D4, Ts-a6995r 6x9's and a Pyle Pla4278 and Boss AR3000D.
On the first option I have the two subs wired as Series/Parallel which gives me 4 ohms on two bridged channels. Then I have two 6x9's each on the other two channels. This is how I have it wired right now. I would like advice if there is any about wiring them a different way. From what I understand I am only using one coil per sub the way I have it wired right? Should I just wire them separately so I can get 2 ohms from each sub and have them wired to their own channel per sub on the amp? I am kindve lost. Here is a website to show you how I have them wired right now, its the second picture...
Rockford Fosgate® - Woofer WiringWizard
On the second option I would connect the subs on the boss ar3000d mono amp and the 6x9's on the pyle amp. Once again how would I be able to connect both subs to either get a 4 ohm or 2 ohn load on that amp?
CREATURE58
CREATURE58
San Diego, Ca
CREATURE58
