Newbie question again, sorry...
Ok so my final options (if you have followed my other posts) are these two setups...
1. Two DVC TS-W3003D4, Ts-a6995r 6x9's and a Pyle Pla4278. Or...
2. Two DVC TS-W3003D4, Ts-a6995r 6x9's and a Pyle Pla4278 and Boss AR3000D.
On the first option I have the two subs wired as Series/Parallel which gives me 4 ohms on two bridged channels. Then I have two 6x9's each on the other two channels. This is how I have it wired right now. I would like advice if there is any about wiring them a different way. From what I understand I am only using one coil per sub the way I have it wired right? Should I just wire them separately so I can get 2 ohms from each sub and have them wired to their own channel per sub on the amp? I am kindve lost. Here is a website to show you how I have them wired right now, its the second picture...
Rockford Fosgate® - Woofer WiringWizard
On the second option I would connect the subs on the boss ar3000d mono amp and the 6x9's on the pyle amp. Once again how would I be able to connect both subs to either get a 4 ohm or 2 ohn load on that amp?
You have them with all vc's wired. Leave it man. The only other way would be a 1 ohm load and you'll roast that amp.
CREATURE58
CREATURE58
San Diego, Ca
CREATURE58
