98 Dodge ram 1500, 3 inch lift, 18" rims, 35" tires, Decked out in ALPINE ☻
jake21
Lifted > Lowered
Hey CA, I am just finishing up a few projects on my 98 dodge ram 1500. I am doing some fiberglassing for it along with a lift kit, rims, and tires.
I first built a box to go in the back seat of the truck as a console that holds 2 Alpine Type R 12's
Each chamber sits at 1.3cu and is tuned to 34Hz, Sounds pretty **** good.
Here is the door panel which holds An Alpine Type R component set with LED's behind the grill and a neon tube.
Here is a list of everything installed audio wise:
HU: Alpine Cda-9886
Front speaks: Alpine Type R 6.5"compenent set
Rear speaks: Alpine Type S 5.25" coaxials
Subs: 2 Alpine Type R 12's
Amp: Hifonics Brutus 1608d
Screen: Savv 7inch LCD
DVD player: (to be decided)
I will be adding on as time goes so keep updated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Lookin good, nice glass work.
One question though, why did you opt for such a small chamber for each sub? Space limitations? I would have put them in about another cube bigger a piece......atleast.
yes, space limitations....
i have no idea what to do for my Fi Q 12" in my pickup. I have a 1.5cu ft. sealed box sitting behind the middle seat on top of the transmission. I really want to go ported but i dont know how i would without losing my backseat. Is your pickup a quad-cab? Good build man, i wish i could use fiberglass but its too expensive to have someone do it for me.
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
4K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
jake21
Lifted > Lowered
jake21
Bozeman, MT
jake21
