yotamutt
Hello all,
I’ve been researching car audio for a little while but I would really appreciate some advice for the set up in my 2004 Tacoma. The fronts are 5x7 components. The rears are 5x7 w/o separate tweeters. I’m fairly sure I want to go with the four components listed below.
Any opinions on this set up are much appreciated too.
Head Unit - Pioneer AVH-P4100DVD
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/AV-Receivers/AVH-P4100DVD
Amplifier - Alpine PDX-5
http://www.alpine-usa.com/US-en/products/product.php?model=PDX-5
Sub - JL audio stealth box w/ 10W3v3 Sub
http://mobile.jlaudio.com/products_stealthbox_detail.php?fit_id=1424
Rear speakers - Boston acoustics SL-80
http://mobile.bostonacoustics.com/car/car_product.aspx?category_id=14&family_id=94&product_id=264
It’s the front component speakers that I’m not as sure about. So far I’ve found these to pick from. I think I prefer to keep them 5x7 rather than go with a plate or bracket for round speakers, except of course the SL80s since they are made that way.
JBL - GTO8608C
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO8608C&Language=ENG&Country=us&Region=USA&cat=COS&ser=GTS
Jl audio – C5-570
http://mobile.jlaudio.com/products_components.php?comp_id=444
Diamond audio - D672
http://www.diamondaudio.com/content/view/174/193/
Memphis – 15-MCS57
http://www.memphiscaraudio.com/products/speakers/mclass-component-speakers/
I’m obviously not an Audio buff. I only know what I’ve learned recently doing my research. I listen to Rock, Metal, Reggae, Alternative, Folk, a little bit of Hip Hop and some other crap. I’m mostly concerned about sound quality.
Any advice on the set up above or the front speakers I listed would be a big help.
Also any speaker you might recommend that would be better than what I found please let me know.
Will the different components I’ve chosen work well together as far as enough wattage from the amp to cleanly power the speakers? Should I be concerned running speakers with and RMS of 75 watts with an amp that is also rated at 75 watts RMS. I keep hearing that the amp RMS wattage should be higher than the speakers.
Thanks for your help!
JBL - GTO8608C
Jl audio – C5-570
Memphis – 15-MCS57
