5V Power Source 2016 Ford F150
not helping here but why would you need 5v for a sirius radio
is this a non-car radio you're using?
i guess you could just use a basic voltage limiting circuit to cut the voltage assuming it requires dcv
It runs off a cigarette lighter, however I want to hardwire to the battery that way I keep both of my cigarette lighters open for cell phone chargers. I dont want to solder onto the cigarette lighter and then run that to the battery unless I have to. I just feel it will look sloppy and I am attempting to find a cleaner install option.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
380
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
644
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
468
Black Truck 10
Black Truck 10
Houston, Tx
ummduh
    May 24, 2024
