5.25" neo sub box ?
sqhertz
welp , i finally ordered it because they went on sale for $19 a pop ( http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-831 )and so did the 25w plate amp. i know some will say its pointless but this will be for a computer system and i dont need it to be loud as piss because it will be right infront of me.
now , what size box should i throw it in? .2 cuft sealed? or should i go ported? the sat.s it will be paired with play down under 100hz but roll off around 120? or so. i have not measured that , but that is my rough estimate. i would like it to be fairly flat , some peaks are fine but not too much.
construction will be done in .5" mdf with the same finish as the satilites (see avatar).
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'd go ported, about 0.6 cf tuning around 34-36hz. This should give fairly flat response from the low 30's on up. If you want a slight boost you can tune as high as 40hz, giving up some low end performance. If you want more extension you can probably tune as low as 30-32hz. I'd get an adjustable tube port so you could play around with the tuning.
well for now , i was planning on a slot port because im , well , broke. and i already placed my order.
it will be mainly for music , but rarely , ill hook it up to the TV and watch a movie or play xbox. i think the 30-32hz should do me well. i just dont want it to overpower the sats being ported.
playing around with the subwoofertools program , it gives me this huge *** box that i dont really want. this will probably end up under the desk and i like the foot space.
whats your thoughts on a sealed enclosure?
well for now , i was planning on a slot port because im , well , broke. and i already placed my order.it will be mainly for music , but rarely , ill hook it up to the TV and watch a movie or play xbox. i think the 30-32hz should do me well. i just dont want it to overpower the sats being ported.
You could have brian design you a box, im not that experienced with HT so i dont think i could do it.
i could , but probably at a cost. im broke at the moment. i think i may just go sealed. something betweem .2 and .4 cuft.
Your program must be flawed or it may have a mistyped T/S parameter. I modeled it in WinISD with the numbers I gave you and it looks good. If you go with 30-32hz, go slightly bigger -- maybe .7 or 0.8 cf.
I think you will like a ported box much better for this sub.
ill play around with it tomorrow.
how would the upper end extension be? and its 12-16 sqin of port per 1 cuft , correct?
ill just go for a sealed box. i got enough scrap mdf to play around with for now.
10"w x 8"h x 10"d will give me .32cuft before displacement, that too big?
8 x 8 x 10 would be .255cuft...
well , the sub and amp came in today. i love PE.
box is being built as i post. should have a first impression review by tomorrow.
sqhertz
sqhertz
Miami ,Fl
sqhertz
