4ohm or 2ohm Type R subs?
Yeah, this is a budget setup. Those look like good amps, but I'm hoping to keep the whole system around $400. (I only paid $1100 for the car //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
So unless anyone knows of other good cheap amps, I think I'll go with that PG amp and a 10" type R and wire it like the diagram. 400rms amp to 500rms sub wont be bad for anything, will it?
I would run more power then 400w and alot of these companies rate there amps at different voltage's so, you may not even see the 400w..
Will it hurt the sub running that to it, or will I just loose a little sound quality?
I'm having a hard time finding a mono sub with more than 500 watt rms, let alone a class d, for around 100 bucks.
XxAdioxX
XxAdioxX
IL
XxAdioxX
