4000 watt electrical upgrades?
yeah 200a alt would work well and have at least 2 deka's in the back. excessive amperage can make up to a 200a alt for me without having an extra bracket, i'd hit them up. their prices are pretty good
other than adding about a mile of 1/0 i couldnt have said it better myself
and Nathan from excessive amperage is awesome to deal with.
lol yeah the 0g is gonna kill you. go with welding wire, you'll save quite a bit of $$. AFAIK weld wire is OFC as well
groaned back
Dcpower engineering is good. Got mine from there hsd to wait a bit tho. Mechman I hear makes good Alta, nate a excessive amperage is a good Guy very helpful. Nate along with stan from DC helped me on non alt related questions. An a Guy sells dekas for cheap in the classifieds. 200a an 3 bats should be fine.
Ditto, good battery up front, minimum 2 good ones in the back and HO alt, or 4-5 batteries in the back and stock alt....depends a bit on your listening habits, the amp, and what you're running it at. Also had good experience with Excessive Amperage building my alt.
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
trenthonda1
trenthonda1
Florida
hispls
    May 20, 2024
    May 20, 2024
