4 Gauge for 1k Rms?
It depends on the length! Without knowing how long your power wire is none of the advice given in this thread is relevant.
Go to Basic Car Audio Electronics
Use the navigation panel on the right to find number 16. Wire
Scroll down between 1/3 and 1/2 of the way and you'll see the "Power Wire Calculator"
Viola, input your information and it will tell you if your setup is insufficient
Ext cab pickup.... My guess 12 feet or so max.....should be sufficient for 1KW audiopipe.
Going bigger won't hurt either and you can always pull the wire for your next build.
Thats why I added ext cab truck..Roughly 12 ish feet with like a 2 foot ground if that. I think I wired whole truck ground/power with 15 ish. Havent done big 3, truck has 8g but I have some extra 4g I could do it with which im sure would help.
kfx450r
kfx450r
Hammond, Louisiana
mrToester
