3k watts to work with
I didnt say it was the amp?? Its not a bad battery it rests at 12.5 and goes to ~13.8 idle. no isolator. I have pics and videos im uploading now.
He's trying to say that when he wires his 2 ohm stable amp down to 1 ohm (.5 per internally strapped amp) then it goes into protect. This is a problem with the amp, not his electrical. Those amps don't like to go below 2 ohms, but with the right voltage will easily do rated at 2 ohms.
It works when I have it set up like this...
When I have it like this its loud but goes into protect when I crank it or when hard bass hits.
My voltage stays at about 13v when I have it the way the first picture is, but when I have it the second way pictured my dmm goes all over the place and isnt accurate at all.
Bro, you don't have to be a rocket scientist to see why it doesn't work in the second pic. It clearly says 2ohm min, when bridged. And you just said your sub was a D2. lol, hope you get it figured out.
Bobby322
Bobby322
TX
kowboy
