3k watts to work with
Bobby322
Well I just got a nice new AP30001d, but its being a pain in the *** cause I cant run my Treo SSX at 1 ohm on it. Im probally going to go with a different sub setup. My current box is 3.5 cuft and its not a truck type box and takes up a lot of room. So what sub or subs should I be looking for that can take 3k or 1500 a peice and work well in a smaller box?
I doubt that you'll be able to trade a big power 15 or 2 10s that would wanna trade for your woofer. Why not just adjust the gains properly and run the Treo??
Huh? I've tried adjusting the gains but when I try to crank it, it goes to protect. I just have it in 1 channel at 1500w right now.
you need to be investing in you electical if the amp goes into protect running only 1 channel at 1500 watts then trying to full tilt it at 2 ohms bridged would not be any better for the amp.
It doesnt go into protect on 1 channel @ 1500w. It only goes to protect when I crank it at 1 ohm. Id hate to invest all this money into electrical for an amp that isnt made to go to 1 ohm.
that makes no sense. is the amp bridged at 1 ohm right now or are you running it at 1 ohm off of one of the channels?
I have it at 1 ohm on 1 channel. My sub is wired to 1 ohm and I have the wires in 1 channel of the amp.
exactly what i am saying if you get a new sub and are able to finally bridge the amp at 2 ohms for 3k its gonna go into protect alot faster or blow if its already doing it on just one channel.
Bobby322
Bobby322
TX
kowboy
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
