3 Way Active With Subwoofer And Rear-fill
Madness0528
My headunit is Pioneer DEH-80PRS.
I have two sets of CDT 6.5" component speakers
I have one 8" subwoofer
I have three 4 channel amplifiers.
I am considering switching the DSP from standard to 3-way.
My question is this: With 6 channels of headunit RCA outputs supplying the signals for the front stage, how does one get the rear and subwoofer signals?
I appreciate any input and thanks in advance. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You don't, not with this head unit or any current production head unit under $1,000. An additional DSP is required to keep your rear fill and properly tune all speakers.
Thank you for the reply, EWE. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So would i be better off doing the 3-way front stage alone or the more traditional front, rear components and sub in trunk?
OR, should I add some sort of DSP to the 3-way so that I can add rear-fill and subwoofer?
Money is an issue. I'm not spending more than $200 bucks.
Using time delay properly you can run a sub ...rear midbass and front highs....and make it sound like the substage and midbass are right in front of you...It just takes a lot of adjusting ...and time and patience
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
So, assuming that you aren't using an LOC and are using the hi-level (speaker) inputs, use the speaker leads off of any of the R/L speakers (front...
39
5K
10
623
10
972
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
785
Madness0528
Madness0528
United States
Louisiana_CRX
    May 20, 2024
    May 20, 2024
