2ohm V 4ohm speakers
ok if my RECIEVER is rated @ 22 rms per channel and 50 watts peak X 4
is that rated @ 4 ohms?
Yes (depending on the deck, I doubt you'd actually get a full 22w out of it at 4ohms). .
if i hook up 2 ohm speakers like infinitys what would the power be?
In reality, probably not much more than that rated 22w
Headunit's internal amplifiers weren't designed to provide large amounts of power, especially into low impedance loads.
Double check also. Your headunit's amp may not even be stable into a 2ohm load per channel.
they may also be idiots... or the ohm loads on the tweeters may be higher, allowing you to bridge them in a way that it makes a 4 ohm load.. or they could know basic math and how to put the speakers in series of parallel loads so that it all comes out to 4 ohms... math on resistance is weird... but if you do it right, you get mad props from audiophiles around you... considering you successfully hooked up 28 speakers in your car off of a single 4 channel head unit... lol theres a calculator online that shows how to put speakers in parallel and in series and you put in the ohm loads and it spits a number at you... search google for it... hell i even did it for you... go here http://caraudio.biggz.com/downloads/ohmcalculator.html and download that program... youll be happy... youre welcome
Yes - because people that consider themselves true audiophiles will be greatly impressed by an install that (a) Is incredibly impractical and (b) sounds like hammered crap (as driving 28 speakers off of a headunit inevitably will regardless of whether or not you got the impendence shown to the deck's internal amp right or not)
so that 22 rms rating is rated @ 4 ohms
the deck most likely cant power 2ohm speakers
a 2ohm stable amp would power the infinity kappas (would it sound good)
thats my summary am i right or wrong?
if i have 4 speakers powered by a 4 channel amp and the speakers are 4 ohms will they still recieve power from the head unit or is it just the amp now?
airtas
airtas
NY
airtas
BP1Fanatic
BP1Fanatic
