2ohm or 4 ohm
If your amp is 2 ohm stable, then buy the 2 ohm subs (assuming they are dual voice coil). That way you can wire both subs to a 2 ohm total load. By using 4 ohm dual voice coil subs, you would only be able to achieve a 1 ohm or 4 ohm total load.
The L7s voicecoil options are either dual 2 ohm or dual 4 ohm, right?
2 dual 4 ohm subs can be wired to 4 ohm or 1 ohm
2 dual 2 ohm subs can be wired to .5 ohm or 2 ohm
If you want the most power out of you amp and its only stable to 2 ohms then get 2 dual 2 ohm L7s.
yngpimpin
yngpimpin
Ga
viebotls
BP1Fanatic
BP1Fanatic
