2nd battery question
  • 2
I do not like to MIX different types of batteries. How large is the sub amp? Wattage ? And are you running another amplifier for mids and highs? What size Supply and Ground wire are you using for amplifier /amplifiers? Have you done the Big3 Yet?
About to start install my vic esploded quickly seriously.
0 ga welding cable run to back
Big 3 using same wire
Underhood 850cca newer battery lead acid but never goes dead
Rear batt duracell agm 650cca 65ah g34
Alternator upgrade is not an option at this time.
Max amp draw around 300a on a sine wave burst, or so
Class ab 2800w beast lets hope.
Do not plan to ever play near full tilt for long and not loud at idle
Sql setup ive been trying to hear once tuned and turned up for once without failures lol
The subs alone are worth more than the whole exploder so this is a low budget oriented setup.
Why i say no alt upgrades, batteries for some reserve and voltage stiffening some
Real world id guess on music at most might see 200a draw on low long note
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
ThatChevyGuy
slater
    May 2, 2024
slater
    May 2, 2024
